Tire Size Definitions
What do
the numbers mean?
Okay, I'm making this up as I go along, but here are what I believe tire
numbers mean. For the most part, I'm pretty sure I'm right.
A. Wheel
Rim Diameter - The outer diameter in inches of the wheel that the
tire is designed to fit.
B. Tire Type - "R" stands for Radial. I believe all modern
tires are radial, but in the old days they were bias-ply.
C. Tire Speed Rating - This letter corresponds to what speed the tire
is designed to withstand under optimal weather conditions.
D. Aspect Ratio - The width of the sidewall, it is a percentage of the
Tire Width.
E. Tire Width - The overall width of the tire in millimeters (mm).
Figuring
Tire Dimensions
Using these numbers, you
can easily figure the following tire dimensions:
Tire Width
(w) - this is clearly marked on the tire. On the above example, the tire
is 225mm wide.
Sidewall Height - Take the Tire Width as a percentage, and multiply it
by the Aspect Ratio. On the above example, that would be 225mm * 60%, or 225
* 0.60 = 135mm. So the sidewall height is 135mm.
Overall Diameter (d) - Take the wheel rim diameter, and add it to 2 *
Sidewall Height. For example, 16" + (2*135mm). Of course, we have to convert
either the inches to millimeters or vice versa to do the math. 2*135mm comes
out to be about 10.6". Add that to the 16" wheel, and we get a total
of 26.6" as the overall diameter.
Common
Tire Talk
When people say "40-series" or "50-series", they're simply
talking about the Aspect Ratio of a tire. For example, a 245/40ZR18 tire and
a 255/40ZR18 tire would both be "40-series" tires.
When someone calls a tire "Z-rated" or "V-rated", they're
talking about the Tire Speed Rating.
When someone is talking about "245-wide" tires, they're talking about
any tire whose overall width is 245mm.
