GM's factory ground-effects
are among the best and cleanest looking you can get. The ground-effects on the
high-end Grand Prix's have always been nothing short of stunning. It should
be possible to add factory ground-effects to any low-end Grand Prix. This would
require getting ahold of the ground-effects on the sides and doors, as well
as new front/rear bumper covers. These parts can be found for the best prices
at auto salvage yards. They can also be purchased brand new from any GM dealership.
| The 1989-1990 Pontiac Grand Prix Limited (turbo model) and 1991-1993 GT, GTP had the same side ground-effects and rear bumper, but the 89-90 had a different front bumper fascia due to the composite flush-mounte headlamps. The 91-93 used the mini-quad headlamps. The 1994-1996 ground-effects were similar to the previous model years, but was rounded off for a more contemporary appearance. |
Ground-Effects kit from Erebuni Corporation Style 103.
Erebuni Corporation, Part No. 546 |
This
is the factory-style rear wing by Wings West, designed for the 1992-1996
Grand Prix, but since the trunklid hasn't changed, I believe it will
also fit fine on 1988-1991 GP's also. This great-looking rear wing
is available with or without a 15.5" LED brake light. This is actually
better looking than the actual factory wing, because the factory wing
uses a regular under-hanging brake light. |
This is a
BMW M3-style wing for the Grand Prix it is designed for the 1992-1996
Grand Prix, but since the trunklid hasn't changed, I believe it will also
fit fine on 1988-1991 GP's also. It is available with or without an LED
brake light. |
