This is the page about my old car stereo. I liked it a lot, but it was just
  too unreliable. The MDX-400 head unit repeatedly kept breaking down to where
  it would skip on recordable MiniDiscs. Since my favorite tunes are on MiniDisc,
  the MDX-400 had to go. I sold it in early 1999 and bought a new system that
  will hopefully prove more reliable.
    | Head unit
      SONY MDX-400 AM/FM 4-MiniDisc
      changer, competition quality 4V preamp outputs only. This is one of the
      slickest head units I have ever seen.
    | CD Changer
       SONY CDX-805 mobile ES 10-disc CD Changer supporting Custom
      File (user can name discs) and CD-Text (new CDs have disc/track names).
      Controlled entirely by head unit. Has digital audio output too. I think
      I paid too much for this especially since MiniDisc has almost made me give
      up CD's.
    | Digital Preamp/Digital Signal
      Processor
      SONY XDP-U50D This is a mobile ES digital preamp which has
      two analog line inputs and two digital TOSLINK fiber-optic inputs. It gives
      the MDX-400 10 DSP surround modes, several subwoofer cutoff frequencies,
      digitally aligned seat positions, and more.
    | Power Amplifiers
       Two huge trunk mounted Sherwood XA-5400 4/3/2 ch amplifier.
      Cost well less than $1/watt NEW, but to my surprise, is not bad at all.
      75Wx4 continuous (RMS) into 4 ohms at 20Hz~20kHz. MOSFET power supply, discrete
      output transistors, automatic cooling fan, gloss black. Got favorable reviews
      in Stereo Review's Nov. 95 issue, they found it will produce even more RMS
      watts at 14.4V because the power supply is unregulated (93Wx4 or 219Wx2).
    | Subwoofers
       Two 12" JL Audio 12W1-1 poly-cone subwoofers each getting
      150W RMS (or 176W RMS@12V according to Stereo Review's review of the above
      amps).
    | Rear Fill Speakers
       Pioneer TS-A6908 6"x9" 4-way quadaxial?, 200W max., 28Hz~30kHz.
      Polypropylene cone.
    | Graphic Equalizer
       SONY XE-8MkII half DIN 7-band with dual frequency selectable
      subwoofer cutoff frequency, 4 user EQ preset curves and 3 factory preset
      curves. 3 mode 3-color LCD 7-band spectrum analyzer display.
    | Amplifier Power Wiring
       I used some fire retardant, super flexible, thick insulation
      AMP KING wiring. 4 ga. 1672 strand OFC main amp power cable which terminates
      to a generic power distribution block and splits to 8 ga. 665 strand OFC
      wire (used for amp supply/ground cable). I used a Phoenix Gold QuickSilver
      50A Circuit Breaker by the battery. Yes, I know, not as good as a fuse,
      but a hell of a lot cheaper and should, in theory, be equally as safe.
    | Front Dash Speakers
       Blaupunkt RL4027 4" 2-way coaxial, 70W max., 49Hz~25kHz.
      Resin laminate woofer and dome tweeter.
