Showing content with the highest reputation on 03/26/2025 in all areas
  1. GnatGoSplat
    Wiring diagram explain please
    Do your heated seats work? Looks like heated seat relays are powered by the same wire from the BCM. I couldn't find how the wire is routed, just a view of the BCM. I did come across an interesting passage in the Rear Window Defogger Description text: "If battery voltage is low, the BCM will disable the rear window defogger by removing the battery positive voltage supplied to the REAR DEFOG relay coil." How's your battery voltage?
  2. AWeb80
    Fast Forward Performance. FFP
    Update. the 9.6121 pads work perfectly. I sprayed them down with silicone during install and not a peep or a squeak out of anything.
