Showing content with the highest reputation on 01/03/2025 in all areas
    Factory exhaust fun fact
    That's OEM m'boy.....no muffler shop involved, the GT coupes that were fitted with the dual exhaust, & the STE's were fitted with that small left side muffler. It was done that way to get needed clearance under the floorpan, you notice that the left side floorpan has no heatshield in place to protect the fuel filler hose & the evap lines, but the right side does have a heatshield. That small muffler is fitted with a strap-on flimsy heat deflector that does literally nothing. If you toss the original rusted out mufflers don't toss the trumpets, keep them, those are near to the point of being unobtanium.
    Cutlass Supreme early development pics.
    A friend of mine bought this off of Ebay and wanted to share it with everyone. Pretty cool historical information of the car's development.
  3. Amanita
    When I win the Mega Millions I'm going to produce replacement door handles that don't break. If you would like to support me in this endeavor of spending tons of money on lottery tickets please write me a check.
  4. bluecalais79
    x2 on that, but, IMHO I wish they could have made the 2 doors with door handles in the door and not in the B-Pillar. These handles are nothing but headaches. And, the Verts would not have needed a basket handle (?) I'm needing to replace my LH Door handle. Again.
  5. White93z34
    3.8 Series 1 5-Speed regal
    For once I condone a thread being resurrected 22 years after the fact.
  6. SuperBuick
    It took me 22 years but I finally did do that manual swap
  7. Black92GS
    My 91 z34 is bogging down and misfiring?
    Not a 3.4….but fuel and ignition wise they are very similar in how they operate. Not a bad idea to watch these to get some troubleshooting ideas
  8. 55trucker
    Shame that the engineers at PMD did not keep this overall design for the flanks for the GP..... Everything above the beltline is the same as what went into production but all below that was tossed. This prototype is more in tune with the sides of the other 3 cars of the 1st gen platform, the sides are smoother, do not fold in at the bottom, more complete coverage all of the wheels, body does not taper in at the front and rear. That's a really good looking car, too bad it wasn't kept as it sits.
  9. Amanita
    Also of note it looks like this car has the half pop up headlights that this clay model had as well, though it looks like they are taped shut possibly? Ignore the filename, definitely not from 1988.
  10. Schurkey
    Change your procedure. Stop replacing parts, start diagnosing. The only parts you should be replacing are the sort of "tune-up" items that would be expected to fail after a normal service life. The Usual Three: Verify fuel pressure at prime, at idle, and under load. Most fuel pressure gauge assemblies have a push-button pressure release connected to crappy vinyl tubing. Route the tubing so it empties into a drain pan, then push the button while the engine is running. This simulates higher fuel demand if you can't check fuel pressure on the highway. Fuel pressure should remain steady even with fuel flowing down the pressure-relief tubing. TBI systems don't hold pressure when the pump stops running, but the other fuel injection styles should. How old is the fuel filter? Have you ever dumped a bottle of Chevron Techron Complete Fuel System Cleaner into the gas tank? (Recommended at every oil change.) How old are the usual “tune-up” parts and procedures? Inspect/replace plug wires, spark plugs. Use quality parts sourced from an authorized seller (NO COUNTERFEIT PARTS FROM AMAZON, EBAY, OR OTHER SKETCHY SELLERS!) Be sure the ignition coils will reliably fire a spark-tester calibrated for HEI when the coils are fully warm, and misted with water from a squirt-bottle. Cranking compression test of all cylinders while the spark plugs are removed. Verify EGR, PCV, EVAP, and Heated Air Intake (if used) systems for proper operation. Verify proper electronic spark advance. Replace old O2 sensors unless you can PROVE that they're working properly—old O2 sensors get lazy, they don't provide accurate data, but they do provide “data” that fools people into thinking they're “working”. Connect a scan tool (NOT a crappy “code reader”) and look for “codes”. More important, look at the data stream to verify EVERY sensor and computer output. Verify fuel trims during the time that the vehicle is not running properly. Look for misfire counts for each cylinder (OBD2 only.) “Codes” have official diagnostic procedures that will be found in the service manual set for your vehicle.
