Showing content with the highest reputation on 11/26/2024 in all areas
  1. runt
    Getrag 284 Serviceability
    https://web.archive.org/web/20161019020737/http://www.rodneydickman.com/n36.html I did find that.
  2. Mach 5
    Getrag 284 clutch hydraulics
    wow thats crazy i had to look in to this. been out of the w-body world for a few years now crazy to find parts are unavailable. the 284 master is larger bore but same slave between both 282-284 trans. so with a 282 master the pedal would be softer and pedal release height lower. I guess knowing this now.. Im going to have to figure out a replacement solution to fix this issue. maybe fab an adapter for a 2 bolt setup something more common and universal. right now im running the 282 master with a braided line to an internal slave setup 284 trans twin disc with pedal limiter. maybe we can make a aluminum adapter that screws in to the firewall? gotta keep these dubya bodys alive!! also. i heard Rodney Dickman is shutting down and selling the business.. crazy! good luck ion your search. ill ask around see if I can find any parts. -Jarek
  3. carkhz316
    You can use the 282 master for a 284 transmission. The only difference is the size of the internal piston. I can't remember if its smaller or larger, but it'll only make for a slightly shorter or longer pedal throw.
