      9,278
  2. rich_e777
      2,641
  3. ninipu1
    ninipu1
      15
  4. Megavolt-380
    Megavolt-380
      165
Showing content with the highest reputation on 08/01/2024 in all areas
  1. Bake82
    Removal/Installation Front SubFrame
    Great pic of the 3.4 mounts! that bracket also bolts to a mount and then to the subframe. There is a support in the back that the older subframes don’t have. it’s the same for the manual trans cars too! (The metal mount is different but still mounts to the subframe the same). same with the front mount, I’m certain the older ones do not have those provisions.
  2. Galaxie500XL
    Idle Relearn Procedure
    I was searching today for the idle relearn procedure, and realized it comes up often on the boards...so since I found it again, thought I'd paste the link, and procedure here. Hope it helps someone! http://www.w-body.com/showthread.php/14921-Idle-Relearn-Procedure?highlight=Idle+relearn+procedure 1. Reset ECM by pulling ECM fuse (underhood) for a few seconds. 2. With A/C turned off, start car and immediately put it in Drive with your foot on the brake. 3. If the car does not start initially, keep trying WITHOUT putting your foot on the accelerator. 4. Let the car idle in gear for at least 5 and no more than 7 minutes. 5. Shut off the car for 10 seconds. 6. Start engine, place in drive and let idle for 5 minutes. 7. Shut off engine. 8. Idle is learned.
  3. jeremy
    Q18. What is the correct idle re-learn procedure? A18. 1. Reset ECM by pulling ECM fuse (underhood) for a few seconds. 2. With A/C turned off, start car and immediately put it in Drive with your foot on the brake. 3. If the car does not start initially, keep trying WITHOUT putting your foot on the accelerator. 4. Let the car idle in gear for at least 5 and no more than 7 minutes. 5. Shut off the car for 10 seconds. 6. Start engine, place in drive and let idle for 5 minutes. 7. Shut off engine. 8. Idle is learned. courtesy of Shaun
