Showing content with the highest reputation on 06/23/2024 in all areas
  1. SuperBuick
    Starting the hunt for a 91 Grand Prix GTP
    If the shifter in the “good car” is fine, and I can get the shifter from the donor car, yes. I figure/hope it will be good karma for when Ill need something “unobtanium” as I go through this restoration. I will let you know in about 2 weeks after I have things and have a chance to look at them.
  2. bluecalais79
    1994 Cutlass Supreme- 2rd, Front speakers
    Kudos and another big THANK YOU to Mr. Jiggity for the photo & text tutoral on this job. Mission accomplished! The hardest part was getting those dang plugs out of the switches. I now have a properly functioning Check Link and as an added bonus the following: * Door Pull - this was loose since I bought the car in 1994. The original screw was found at the bottom of the door. It was reinstalled. * NOS drivers side switchplate and P/W, P/DL switch was installed. The original Power Mirror switch was used as I did not have an NOS one. * Door Speaker - I bought the wrong one, so the original speaker went back in. No matter, as still works fine. I bought a while back a set of NOS front door speakers and I will install these once the ones in the car croak. And not until then. I am no longer afraid of doing this job now. It's not easy but it is do-able. Much appreciated!!!
