  1. 88red4cyl
    88red4cyl
      1,591
      9,287
  3. GnatGoSplat
      9,362
      5,379
Showing content with the highest reputation on 06/08/2024 in all areas
  1. johnnynotell
    Tgp exhaust leak under hood and runs rich
    Thank you thank you for yours and everyone’s help. It is greatly appreciated. I had no idea there was a Facebook tgp group. I will be checking that out thoroughly. Anyway here’s a picture of my old Grand Prix. It was the reason I even knew about the tgp. I thought I knew everything about gp’s at one time. But I didn’t and still don’t. 69 sj I still regret selling it.
    1.5 gen W body swap L36
    You're actually the 2nd newb to inquire about the 90 degree swap in as many days, Mattmac2007 recently did an L67 swap into a 1st Gen GTP earlier this year, he more than likely would be the freshest source for info on what has to be done. He did a thread on the conversion.....
  3. LumiGuy1
    Once this swap is done as the motor n tranny I have are in very good shape. I would love to get looking into the 3500 swap I have 2 1993 luminas so ones staying a daily till the swaps done then id love to get a ton of info on how to do and how easy that 3500 swap is thanks.
  4. pshojo
    L67 swap into 92' Lumina
    Either engine swap you do, you will need different harness, with 3.5 or l67 with 4t65hd trans. Easy way is to spend $200 get then harness and OBDII from Miltzy.
  5. Nas Escobar
    Easiest way is to convert it to OBD2... L67SS has done this, but on a 96 or 97 Monte Carlo. Converting to OBD2 isn't bad if you know what you;re doing, it's mostly repinning stuff. You SHOULD swap out the trans because of the gearing ratio, not to mention the 4T60E is a twig compared to the 4T65E-HD. You want a 65 HD in there mated to the L67, unless you wanna do a manual swap, which I THINK that the F40 from the G6 works. You could also get a non VVT 3.5 from a G6 but idk how much more work you have to do, I just know that the 3500 replaced the 3100 and 3400, which themselves replaced the 3.1 mpfi. The 3.4 was an oddball engine, nothing preceded it nor succeeded it.
  6. Dirty Rockstar
    Upgrade my 92 3.1 4door lumina????
    Definately the 3400 SC'd.. Then dont do up the outside.. Keep it a very plain jane looking car, and race for ownership! ROFL.. jk.. But definately an 00+ 3100, or a 3400 swap SC'd would own.. Im doin a 3100 top end on a 3.1 MPFI block, and Im turboing it
