Showing content with the highest reputation on 05/21/2024 in all areas
  1. cutlassman
    Crankshaft Position Sensor Stuck/Broken Off On Removal Attempt
    Well…that wasn’t fun. The engine support bar is a must. I had to replace the rear subframe mounts since the originals were rusted out. The Dorman replacements are a PITA to install since there’s really no slack in the original bolts, which had to be reused. The old crankshaft position sensor that was broken off was in the top of the pan. I replaced leaking power steering hoses in the process and cleaned up oily wiring and added new split-sleeve wire protectors. The car fired up right away after I had everything reinstalled - definitely a sigh of relief! I lowered the entire subframe to get the oil pan out…replaced the engine and transmission mounts while I had the chance. Definitely use a lubricant and take it slow if you have to remove a crankshaft position sensor.
  2. mike_lumina92
    any ways to make my 1992 lumina Euro 3.1 faster and more powerful
    you see i have a 1992 lumina euro 3.1mpf1 engine and i want ways to make my car faster and more powerful, increase horsepower or at least sound more powerful let me know anything....
  3. 19Cutlass94
    It says turbo
  4. GP1138
    SEARCH, this has been covered in many threads.. there is one big thread that one member has about installing stock Turbo 3.1 parts on a stock N/A 3.1 engine. It was pretty successful.
