  1. Psych0matt
      11,019
  2. GnatGoSplat
      9,275
  3. rich_e777
      2,605
  4. White93z34
      10,738
Showing content with the highest reputation on 03/27/2024 in all areas
    HELP!! AARRGH
    You don't "need" a scantool, necessarily, Its a 93' its not that smart in the first place. Qucik and dirty oldschool should get you pointed in the direction. These methods served me well for years. I'm saying this as someone who owns all the diagnostic equipment at this point in my life. Are the plugs fuel fouled? if they are that's a problem, New or not if they are soaked in gasoline they won't do much, pull it out if its wet and smells like gas then yeah Do you have injector pulse? One bad injector can bring the other 5 down with it. Its not uncommon for them to fail as the cars get older and older. To check it, pull the cover off the fuel rail, unplug an injector any injector. get yourself a 194 lamp unfold the leads and stuff them in the injector harness, does it flash while cranking? if it does plug the injector back in and move to another of the front 3 and repeat, this will rule out the one you just disconnected as being bad Make sure the battery is up to the task, the ECM won't run under ~9v or so. is the tachometer needle moving when you're cranking if not its an indication that the crank sensor could be bad Check fuel pressure, put a small flat blade screwdriver to the schrader valve on the fuel rail, do you get a forceful ejection of gasoline with the depression while the key is on? its probably ok pull the vacuum line off the fuel pressure regulator, does fuel come out of it? if so thats a problem. if you happen to have a small hand vacuum pump pull a vacuum on the regulator if it won't hold any vacuum, thats also a problem Next lets get into the weeds a bit more, the map sensor is located behind the upper intake, is everything connected properly, if its unplugged the car won't start Coolant temp sensor is it connected, if its unplugged it thinks the coolant temp is around -40 or -50 degrees and can often lead to flooding and not starting I mean you did a heap of work to the car do a general sanity check to make sure nothing you did could have caused it. Hope this helps.
  2. cutlassman
    Crankshaft Position Sensor Stuck/Broken Off On Removal Attempt
    I appreciate all the advice. I’ll bite the bullet and drop the pan. The engine support bar is a great idea. A new oil pump makes sense and the power steering lines are leaking a bit, so I’ll knock those out, too. Might as well check out everything else while I’m in there.
    I feel your pain but if it were my car, I would just drop the pan. I haven't done this on a 3.1 car as I own LQ1 cars but it's not a bad job really. Just make sure to clean everything well and you might as well put a new gasket on it. There are instructions in my manuals that require torque for the gasket and the metal tabs in certain areas of the perimeter of the pan flange. You'll also want to add dabs of silicone sealant in the corners of the pan where it goes up and around the crankshaft, etc. Again, the manual recommends this.
  4. cutlassman
    I’ve owned this car for almost 24 years and getting that broken crankshaft position sensor out was probably the biggest PITA since! I was able to get various drill bit sizes into the hole and chip away at the plastic sensor. Unfortunately, when it finally started to loosen, I accidentally pushed the sensor into the block where I could hear it thud into the oil pan. New problem now! After draining the oil, I tried to fish it out through the oil pan drain hole with no luck. The metal middle of sensor is in there, along with about 75% of the plastic surround. Dropping the oil pan is such a hassle, so I may just leave the sensor remains in there and roll the dice. Or, I thought about drilling a 3” hole in the oil pan and then patching it. Anybody have any experience doing anything like that? I haven’t found a suitable plug, yet. So frustrating.
