Showing content with the highest reputation on 03/21/2024 in all areas
TGP hood vent repair.
94 olds vert reacted to rich_e777 for a topic
Do not use the flexible bumper repair stuff, it doesnt hold at all. As soon as I screwed the vent back down it all seperated and I could peel the urethane off clean. So now I`m going to strip it and try again, might do the other just to be sure they match. I used Gorilla glue gel to re-attach the unobtanium and ran a mounting screw down the glued on provision and it all held very nice. Let it cure for 24 hours.1 point -
GnatGoSplat reacted to rich_e777 for a topic
Turned out as a high B+ job, there is still a small spot only someone anal would notice. Rattle can Dupli-color matched up pretty good over several coats of a new to me primer and filler. Here's a comparison pic after the paint dried but before the clear coat1 point -
Tired 88 Cutlass
90sEraWhips reacted to jiggity76 for a topic
He's here. Not consistently, but he does check in once in awhile. He's also on FB. Classic GM FWD Society. Yes, he does both of them. He actually looked at my cluster a few months ago. Sadly, it couldn't be repaired as it was badly damaged. Don't let that deter you though. Each cluster repair is unique and he very well might be able to fix yours. Very fair on price too.1 point -
Larger Rear Brake Rotors(?)
90sEraWhips reacted to 90LuminaEuro for a topic
Check the hoses. I've had several 1G W-bodies, including my current '88 CS. They all had issues with the rear passenger side going through pads and the calipers seizing. My CS regularly smoked brakes. I replaced the master cylinder, calipers in the rear and did a full bleed on the system. Still locked up. Metal lines were intact and in good shape. Turns out, the hose was bad! Collapsed when pressure was taken off and the caliper would only release pressure when I opened the bleed screw. Replace all of your hoses. You can even find steel-braided ones at hawkbrakesdirect.com. just have to look up the 94 Z34.1 point -
W-body engine pull
90sEraWhips reacted to PCGUY112887 for a topic
I will be pulling my 3100 from my 96 GP soon to put in a 3500, and I was wondering where the lower engine mount is? I know the engine has to come unbolted from the tranny, and then the 2 dogbone mounts on top come off, then all lines get disconnected.... but where is that lower mount and is there anything else that has to come apart for the engine to come out? Tranny is staying in the car. Thanks.1 point -
W-body engine pull
90sEraWhips reacted to Heartbeat1991 for a topic
I dropped mine out the bottom all as one unit.1 point -
W-body engine pull
90sEraWhips reacted to DefEddie for a topic
Update for tips and tricks on pulling the whole assembly out from underneath.1 point -
W-body engine pull
Heh oh yeah, I need to get some videos! Still tryin to smooth out my tune, it's being a pain.1 point -
W-body engine pull
90sEraWhips reacted to Crazy K for a topic
WHO??? LOL yeah. I have three frame swaps scheduled right now, actually!!!!!!!!1 point -
W-body engine pull
Ah! Finally got it out! Turns out that left side bracket... well if you unbolt it from the trans, there are 2 bolts. But if you unbolt it from the block, there are 2 bolts towards the top, and 1 down towards the bottom of the engine. I did not see this 1 lower bolt! So about 5 hours of fighting for that. After I undid that, it came right out.1 point -
W-body engine pull
I have been told that everyone swaps their covers because accessories don't fit correctly on the 3500's (including the PS pump). When everything is out and in front of me, if it looks like it will work then I will use it. The cover had to come off anyways for the cam so no biggie.1 point -
W-body engine pull
90sEraWhips reacted to Brian P for a topic
Yeah, just unbolt the pump from the engine (3 bolts accessible thru the pulley holes) lift it up and set it aside. Don't disconnect any lines. What's different about the 3500 timing cover? I remember seeing a 3500 in a car with electric power steering, yet the mount for the hydraulic pump was still on the timing cover.1 point -
W-body engine pull
90sEraWhips reacted to TurboSedan for a topic
i always leave my PS pump in the engine bay when i pull the drivetrain. just unbolt it from the front timing cover and set it aside.1 point -
W-body engine pull
Yay now I have a sticky on both forums! Is there anything bad about turning it the other way? While I was getting my crank pulley off my 3500 I think I turned it the other way a few times Here is my thread on the Powrtuner forums for those who have access http://www.powrtuner.com/index.php?showtopic=6093 I am basically being told now that my 96 PCM is no good for tuning, and that I can directly swap in a 97 PCM to give me more tuning options.1 point -
W-body engine pull
90sEraWhips reacted to slick for a topic
We could add this to FAQ later once all discussion is done. If someone wants to do a write-up of dropping the entire cradle for swapping engines, I'll make it a sticky as well.1 point -
W-body engine pull
You'll still have an oil pressure switch there for the dummy light on the gage cluster. Once in there you won't necessarily see the bolts. With the starter out, you'll see the back face of the flexplate. You need to manually turn the engine and stop when the bolts come into view. There's 3 of them, 120 degrees apart. I rotate the engine using a 1/2" breaker bar on the crank pulley/dampener bolt. Turn clockwise of course. I don't have a pic of this but I'll look around. Yeah I was thinking of trying one of those cams too! I saw your thread on there, I'm on that forum as "Rhedalert". I did a basic tuning method like you suggested, except I went from 3100 settings to 3400 settings. This got me closer. (I have since gone to a 3400 file anyway) I'm hoping we get a 3500 file to view (though I'm just about done with tuning, just curious how the 3500 settings are), but things tend to take a LONG time over there to get anything. I waited over 4 months from the time I purchased the PT to the time I was able to TUNE my Olds. It's tough to get the ball rolling quickly over there if you don't have a 3800, but patience is the key and it will happen.1 point -
W-body engine pull
I have a few minutes at this moment. That lower mount, all you need to do is crawl under the car, and remove the 2 retaining nuts keeping the mount onto its "cup" on the frame. Other things to do.... Bottom: - unbolt AC compressor from bracket and set aside - Remove starter - Remove flexplate-to-torque converter bolts (accessible once starter is removed. You will have to turn the engine manually at the crank pulley to get at all 3) - Disconnect exhaust downpipe (preferred), or unbolt crossover and remove rear exhaust manifold. - Remove right side transmission-to-engine block retaining bolts (I usually just remove the 2 bolts going into the trans diff cone area, and leave the bracket bolted to the engine block) Over: - All hoses including upper, lower, and 2 heater hoses (nearest the throttle body - Remove cables from TB or just unbolt the TB and set it aside - Undo two fuel lines with special quick disconnect tool - Get all accessories out of the way - Unbolt P/S pump and set aside - Remove alternator (preference of mine for added space) keep the bracket bolted to the engine - Disconnect engine wiring harness that goes to the EGR, Throttle body, igniton module, MAP sensor, Oxygen sensor, injector harness, etc and set aside - *** Disconnect knock sensor and oil pressure sensor wiring (You don't want to pull these apart accidentally) - remove crossover heat shield and crossover (optional for added space to get to the bellhousing bolts) - undo bellhousing bolts, disconnect 2 ground wires attached to 2 of these bolts *** ONE Bellhousing bolt in the BACK of the motor is facing the OTHER direction. You can only access this from the passenger side of the car. I usually use a long 1/2" extension and get at it by feel from the passenger side fenderwell. - Support transmission from the bottom with a jack, or jackstand (use a big piece of wood to prevent gouging the pan) - lift up evenly, be sure motor mount lifts out of its cup first, then shake the engine free from the tranny. I may have missed some so I'll add as I think about it.1 point
