Showing content with the highest reputation on 12/19/2023 in all areas
    Trans questions
    LOL...don't give up so quickly, the oversized pin is a common item, the reamer 84573-02K which is used to bore the centre of the piston is discontinued but a 3/8" drill bit that has had the end blunted will do the job (one makes use of a drill press to do this work)
    Trans questions
    No, you're not stuck with the 4t60 clutches at all, nowadays the rebuild kits for the 4t60 would include the latest clutch plates upgrades that can be had. Suggest that you give Sonnax, Global Transmission parts a call or Transmission Parts USA on a 4t65 rebuild kit (assuming you want to purchase the master rebuild kit yourself). You'll want a prior to 2002 rebuild kit, 2002-03 the valve body for the 4t65e was redesigned & improved.
