No, but the inside bolt for the forward lateral link does not come out. It hits the gas tank when removing. GM put it in backwards from what they should have. Either the subframe or the gastank will have to be lowered to get it out. Once you do that and get it out, reinsert the bolt from the BACK, putting the NUT on the front when going back together, like GM should have done. Also remember to install all links/arms and leave the bolts loose until the car is on the ground. DO NOT tighten them with the suspension dropped.
