Showing content with the highest reputation on 02/11/2023 in all areas
  1. Quaraxkad
    Projectors in Cutlass Sealed Beams
    I tested the stock lenses pointed at the wall, and there wasn't a whole lot of difference between the bare projector vs passing through the stock glass lens. There's still a very strong and straight well defined cutoff, and only very minimal amount of light above the cutoff in very small squares. But even so, as I mentioned before, if the stock lenses turn out to be no good I already have a plan b anyway. Once I get one assembly done I'll do a side-by-side comparison of stock. I just need to do a little more trimming of the housing, make some flat spots to ensure a level and straight alignment, and then mount it in place. I suspect JB Weld will be the solution for that, even though it's the "hacky-est" method I can't think of any other way for this particular setup.
