Showing content with the highest reputation on 01/13/2022 in all areas
  1. Jim_rockford_007
    Guess what came in the mail today .....
    got it installed, 8 PSI on the first pull , no knock retard
  2. Garrett Powered
    wondering if i should change my transmission fluid if it brownish looking
    thanks, I will check with the homies on this so I am the designated beer drinker and key turner that gets orders barked at them. when they worked for their other shop they had that snap on machine, now; I am not sure if they do tranny oil changes or just pan drops. if not I will have to get a drain tube.
  3. skitchin
    Frame Brace???
    I work at a pretty large automotive and industrial supplier, can get nuts bolts clips fasteners and pretty much whatever ya need. If you need anything let me know and I can roll some numbers around. I'd love to put together a list of every single plastic clip in these cars and what the supplier's part number is. We buy from Auveco, pretty much THE manufacture of trim retainers.
  4. GnatGoSplat
    turn signals
    A pencil eraser also works wonders at cleaning oxidation off of the contacts.
  5. AL
    95 Grand Prix, No Crank, Intermitant problem
    I meant ignition switch
  6. Header panel I think?
  7. BS009
    This sounds exactly like what I have been dealing with ever since I bought my car. One day I measured the voltage at the starter solenoid and noticed that I only had about 6 volts there, which apparently is not enough to activate the starter. This meant the voltage dropped a lot when the circuit went inside the car. I ended up running my own wire with a relay to the starter to a switch inside the car so I could start my car whenever it gave me a problem. I never really found out what the cause of this was, but a little over a year ago I noticed that my car had just over 13 volts while it was running. I figured this should have been somewhere closer to 14.4 so I ended up adding 4 gauge cables from the alternator to the auxiliary post, and from there to the battery. I also added a cable from the battery to the ground. After doing this I've only had the starting problem maybe 3 times in over a year. Now my voltage with the engine running is also at 14.4 or higher.
  8. BS009
    no rear brakes, hard brake pedal, ABS and brake light on
    So I started my car today to find that my brakes have magically fixed themselves. No ABS light or brake light, and all four wheels are breaking. My car seems to be quite magical as this is not the first time the car has fixed its own problems.
  9. tornado_735
    Did you bother to even check his fucking sig? Jesus, for having so much knowledge, you really are a condescending dickball. Oh yeah, you revel in that. I forgot. My bad.
