  2. mechanic58
    mechanic58
      107
  4. l67ss
Showing content with the highest reputation on 06/28/2021 in all areas
  1. mechanic58
    Looky I got!
    Just picked this up today, ‘93. Unmolested one owner Carolina car. Been parked a long time. Timing belt failure.
  2. vipmiller803
    Replaced Rear Drivers Side Caliper, but that side is smoking excessive.
    To each their own. It’s how I was taught and it continues to make sense. Rattle clips sometimes just rattle themselves. Plus, it cuts down on corrosion, something we can always use less of around here. Although I should be more clear. I do not put grease on the back of the pads, but rather on the top of the caliper piston and caliper end where the pads sit.
  3. mechanic58
    Looky I got!
    Got this thing torn down today and cleaned up. Ordered some parts. I may have it running later this week. LQ1 parts are all closeout priced on rock auto, the timing belt was only $2.14!
  4. Jim_rockford_007
    1999 Lumina 9C3 L67 swap thread...
    Well finally got around to changing the receiver drier and the high pressure service fitting and recharging the AC system, and while I was doing that I had to Tinker with the fans a little bit because one had a bad connection on the passenger side and the fuse was blown for fan 3 so once I replace the fuse and got the fans working for some reason I looked over at the radiator that I pulled out of the Grand Prix GTP and I looked at the fans and they look like they were a lot more efficient than the stock cooling fans on the Lumina because they had a lot more shrouded area. So I pulled the fan shroud off of the radiator and set out to installing it in the Lumina and sure enough I had to remove both dog bones and the one radiator support mount along with the airbox once I did that the fans dropped in like they were made for the Lumina and they work like a champ. AC works way better sitting at a stoplight now in traffic.
  5. mechanic58
    Looky I got!
    You shut your whore mouth when men are talking!
  6. Jim_rockford_007
    Looky I got!
    Needs more L67.
