  1. Imp558
    Imp558
      8
      6,001
  2. Galaxie500XL
  3. MemphisMan
    MemphisMan
      1,553
  4. vipmiller803
    vipmiller803
      550
Showing content with the highest reputation on 10/31/2018 in all areas
  1. jmjp5055
    1994 vert. LED Light conversion
    first pic of led’s
  2. vipmiller803
    Urgent opinion please coolant leak timing cover 3.1L
    Wow... he literally pulled off the pipe, saw that, and just stopped without prodding one bit. Even though the manager made it right this time, I'd be real hesitant to go back there if I were you.
  3. sean1991olds
    Yep- correct you guys... it was the ring off the gasket. When he showed me the gasket initially, it looked like it had no metal rings - not knowing what it was supposed to look like I thought ok on that.. But the whole explanation on the thread/smooth surface didn't make sense to me. I pulled out an old W-Body parts book and looked up the part # then looked that up online where I saw what the gasket really looks like. Thats where I was like damn, thats the ring from the gasket and maybe the other ring fell off or was stuck to the underside of that coolant pipe. The other ring was still on the old gasket just the gasket was so smushed it wasn't easily visible. I went in this morning with printed pics of the gasket (and part number hah) and asked does this make sense (gasket ring corroded onto the timing cover) ? He was like nono... but if you want, we can take a look. Went out and exactly what GTP091 said, flat screwdriver pushed it right off. They put a new gasket on, topped off the coolant, burped out the air and that was that.. Manager made it all free (not that they were out a whole lot) as it was a misdiagnosis. What was so funny was when I headed inside with the mechanic, he was like hey I have some of those gaskets right here. I honestly can't tell if it was just a dumb mistake, or if they were trying to "keep the lights on". The day I came in they were happy to take it in because they weren't very busy heh heh... Had I not taken that picture, and had I not bothered looking up what the gasket looked like, I woulda had no clue, and woulda been charged $1200! I can't imagine what the average person gets taken for!
  4. GTP091
    If I was you I would: try and poke that raised piece off with a flat screwdriver to see if it is the ring from the gasket. It looks like it is to me. If it is then just clean, replace the gasket and reassemble. If not I’d do what imp said and grind it down flush, clean, replace gasket, and reassemble. To grind it down you could use a drill bit that’s much to big to fit the hole, that way you won’t chance messing up the mating surface. Make sure you stuff some clean rags in there very tightly to keep the bits out. You can see shiny aluminum in the hole so I don’t think it’s a steel insert or a helicoil, if it was you would see the threads?. It really looks like that ring from the gasket is corroded on. If that’s the case you should give the mechanic shit for this as that’s a major con job. Gotta keep a shop runnin somehow!:
  5. l67ss
    I hate when I see deals like this...
    Great shape for a 120 year old car lol
