  1. digitaloutsider
    55trucker
      2,070
  3. Imp558
    Imp558
      6,001
  4. vipmiller803
    vipmiller803
      550
Showing content with the highest reputation on 09/09/2018 in all areas
  1. digitaloutsider
    Doubling Down on W-bodies
    This really isn't true. But welcome back! I love the red 'verts.
    95lq1vert's 1994 Cutlass Supreme convertible progress thread
    Like the hardtops the window glass is held horizontal by a guide retainer at the upper rear corner of the glass. If the retainer has worn out & is no longer held in the vertical track then it is quite possible that is the source of your issue.
    lim gaskets
    That engine doesn't require any sort of *special* coolant, regular coolant in a 1 gallon jug (50/50 or concentrate is again your choice, I never use 50/50), whether or not you prefer long-life over normal is your choice (just don't mix them as that defeats the long-life properties). But do NOT use tap water to add to the concentrate, use deionized or at the very least purified water. Tap water is not softened, with time it will develop lime deposits in the system. *One other note* the manifold bolts are torqued to only 18 FT.LBS, an inch lb. torque wrench is far more accurate, most 1/2 drive torque wrenches don't begin to read until 20 ft.lbs. 18 ft.lbs is 215 inch.lbs
