  2. crazyd
    Grand Prix GTP
    What about this?
  3. jiggity76
    Grand Prix GTP
    I try to post W's being up for sale here in the appropriate thread. Nothing comes to mind right now but always looking.
  4. Blink
    Grand Prix GTP
    Hi, I’m trying to find a 91 to 93 Grand Prix GTP in decent shape in either red or blue. any help would be greatly appreciated. thanks
  5. Well, a spring shop will only deal in steel items, they can't fab a glas item, this isn't rocket science, any shop can do the job, they just have to show the determination to take on the task. The glas spring is a parabolic design (thicker in the centre, thinner at the ends, making one in a steel configuration is a no-brainer as multi leaf springs are the same sort of design, One selects the single width of each leaf & the thickness to get the wanted spring rate & load rate, It involves cutting the blanks to the required length to make the stack, because the original is a transverse single spring the time consuming part of the job is the mechanic having to arc each leaf individually & get them near perfect in their arc so that each side off centre is near identical & lets the car sit perfectly level from side to side.
  6. Yesterday
  7. Not far south of Albany NY. Local junkyards have nothing and few suggestions. The spring shops say 'fiberglass, we don't do that' and show no interest in helping out further. Found on in Kentucky, place wants just shy of $400 (350 shipping!). I'd just put in spring struts if knew what exactly to get, I'm reluctant to experiment as that may just end up with a bunch of parts and no money lol. Appreciate the reply
  8. Where do you live & what sort of response from the shops contacted are you getting?
  9. Last week
  10. Finding a spring (and a shop interested in a replacement) is proving difficult. Anyone know of a swap that is the complete spring and strut from another W body or GM car that could 'bolt in'?
  11. 94 olds vert
    convertible carpeting
  12. Ric
    Did the final application of the coupe carpeting work ok in the convertible? I still need to improve mine and would like to buy new soon.
  13. 55 .... Thanks! Def the most and most consice information I've read so far. Some of the links are dead ends (of course, there pretty old) unfortunately but I'm going to attempt to connect some of the businesses and I may have a lead on a spring found on ebay. Thanks again
  14. Schurkey
    Is this normal for a 500 mile engin
    You're being paranoid. Random and light brake cleaner overspray is relatively harmless. Nope. MAYBE you washed the oil off of 'em.
  15. You can look thru this old posting from 2007, there still may be some useful links in there...... the last member I can remember who did coilovers was Imp558, that was near 8 years ago.... or this one....
  16. White.. This is what I'm learning but as you mentioned, it appears it would be a (very?) deep dive and likely time consuming endeavor. I'm exploring a replacement but they are scarce. It would cool to construct the coil strut and install but there is just no enough info to feel comfortable attending it. Thanks for the information and insight.
  17. All I remember about that was at one point people figured out how to build rear coil overs out of mostly off the shelf parts. There was always plenty of discussion around ride quality, and if the stock upper mounts could take the added forces, but to my knowledge no one ever had issues with that part of it. I was never into lowering my car so I can't speak to it, but I see no reason why it couldn't be used to bring the car back up to factory height as well. It might take a heap of searching old threads on here but the information is likely still around from then.
  18. jiggity76
    Bluetooth Module DIY
    Ok, I'll give him a shout.
  19. Anyone know of the mentioned kit or conversation to coilovers?
  20. Thank you for the information
  21. SuperBuick
    I did - and loved it - but no detail on "which wires to solder".
  22. For those in the states one doesn't HAVE to approach CMV, for me they're not far away, but keep in mind that the company has changed ownership & the staff now there are not the staff who used to fab these springs 20 + years ago. The last time I spoke with the current owner John Geropolous none of the staff had any experience putting together one of these multi leaf springs to replace the glas leaf. When the original owner Alex Vitanoski & his son left they took the know how with them. But that aside any capable spring shop can fab up a replacement for the glas leaf, all they need is the car, the old spring & do the formula to make a 2 leaf or 3 leaf replacement that will be either a high arc or shallow arc, oem height or custom height depending on what you the owner are looking for. The indepth part is getting either outboard side of the chassis mounting points exactly the same arc so the back end of the car sits even. Because of their lack of knowledge I did not go to them, instead I used a spring shop close to home to fab what is currently under the car.
  23. There's a shop in Canada that either still does them or did them. Probably worth a call. https://cvmbirch.ca/ Birchmount springs, I want to say back in the day they sold a bunch of them to various members. Other then that its probably used as the only other option.
  24. Have 96 supreme with a bum mono spring. Looking to replace it or put spring/struts in place. I have read about the change to spring struts but finding it difficult to find the part or parts and a how to. The mono leave is difficult to find also it appears. I'm sure this has been addressed here before but I'm new and looking for some definitive suggestions. Thanks
  25. White93z34
    Looks great to me. Spent awhile trying to see what you were talking about. that tiny bit of surface rust I cannot imagine will hurt anything. just an aside. The high res pictures really show how crudely the rocker arms were made. the top edge is really something you can see how they just cleaved the steel when they were stamping them. at least they got the surface finish right where it matters.
  26. White93z34
    Not able to give a great step by step one because last time I did it was awhile ago. and the radios differ so much inside from radio to radio. Last one I did was the 5 band EQ tape deck in my IROC. I found the Left and right audio signals coming from the tuner to the amplifier and severed them, got a small 6 conductor wire, and snaked it out and through the console to a ON-ON switch in the console. one position lets the radio pass through as usual, the other lets the bluetooth module interrupt and go to the amplifier instead. I stuffed the bluetooth module inside the radio itself and its powered by the power switch of the radio so its truly hands off. Been working well for awhile now. So basically I broke out the right and left tuner from going into the amplifier, brought those along with the BT out left/right and another set of wires going back to the tuner so I can still keep factory functionality.
  27. jiggity76
    Have you seen his video? He doesn't go in depth on it, (MemphisMan), but he does explain a little bit about it. I would reach out to him for the details...or I'd be happy to ask on your behalf.
  28. SuperBuick
    Does anyone have a link to a good DIY for adding a bluetooth module to a stock 1992 tape head unit? I saw @MemphisMan and @White93z34 have done it, and others, but searching here I can't find a step by step for dummies like me. Any help appreciated!
