  2. SuperBuick
    Bluetooth Module DIY
  3. Last week
  4. rich_e777
  5. Black92GS
  6. SuperBuick
  7. White93z34
    TRW Keyless Entry module
  8. Black92GS
  9. GnatGoSplat
  10. 55trucker
  11. primergray
  12. GnatGoSplat
  13. White93z34
  14. rich_e777
  15. rich_e777
  16. Interesting... didn't the manual show three ports on the exhaust manifold, and this shows just one? The plug wires come up from below there on 91-93, whereas it was relocated to the upper left in later years. That pipe probably wouldn't work due to interference with the plug wire routing.
  17. You're welcome. Something to investigate...these are 96 LQ1's. This is from a random Google search of 2 - 96 Monte Carlo Z34's. Looks like they have that same silver pipe on the front headers. Since we know the last year for the manual LQ1 was 92/93...and these are obviously automatic cars, maybe the same or very similar setup was standard on all 96-97 LQ1's by then. If so, this will help with the availability of possible parts prospects.
  18. Awesome, thanks guys. Looks like I don't have the proper manifold to connect that pipe even if I had it. PO must have swapped it out.
  19. White93z34
    its LQ1 5 speed only. Pipes 3, 20 connect to the exhaust manifold Pipe 17 connects to pipe 9 and the air pump, part 10
  20. I'm just guessing here but it looks like there is 2 points of entry? One...the area where the system goes into the front header. The second one...up topside where that hose goes into the sensor thingy on the end of the plenum.
  21. Earlier
  22. Elvira
  23. crazyd
    Power steering whine
  24. I know what this is and what it does. On my C5, it is called an Air Injection Reaction pump, and it pumps fresh air into the exhaust at startup to accelerate lighting off the catalytic converter, like blowing on a fire to get it burning, to reduce startup emissions. I don't know if this is specific to manuals or the 3.4 or even 91-93s, but I can't find any information about it in the 1992 factory service manual. If your car has one of these, where does the pump's outlet hose connect where it comes into the engine bay near the AC compressor?
  25. 55trucker
    In the GP it's mounted to the topside of the right rear parcel shelf next to the speaker.
  26. mdpierce8
    Appreciate the response. I’ll see what I can do this weekend.
