  2. White93z34
    TRW Keyless Entry module
  3. Black92GS
  4. GnatGoSplat
  5. 55trucker
  6. primergray
  7. Yesterday
  8. GnatGoSplat
  9. White93z34
  10. Last week
  11. rich_e777
  12. rich_e777
  13. Interesting... didn't the manual show three ports on the exhaust manifold, and this shows just one? The plug wires come up from below there on 91-93, whereas it was relocated to the upper left in later years. That pipe probably wouldn't work due to interference with the plug wire routing.
  14. You're welcome. Something to investigate...these are 96 LQ1's. This is from a random Google search of 2 - 96 Monte Carlo Z34's. Looks like they have that same silver pipe on the front headers. Since we know the last year for the manual LQ1 was 92/93...and these are obviously automatic cars, maybe the same or very similar setup was standard on all 96-97 LQ1's by then. If so, this will help with the availability of possible parts prospects.
  15. Awesome, thanks guys. Looks like I don't have the proper manifold to connect that pipe even if I had it. PO must have swapped it out.
  16. White93z34
    its LQ1 5 speed only. Pipes 3, 20 connect to the exhaust manifold Pipe 17 connects to pipe 9 and the air pump, part 10
  17. I'm just guessing here but it looks like there is 2 points of entry? One...the area where the system goes into the front header. The second one...up topside where that hose goes into the sensor thingy on the end of the plenum.
  18. Elvira
  19. crazyd
    Power steering whine
  20. I know what this is and what it does. On my C5, it is called an Air Injection Reaction pump, and it pumps fresh air into the exhaust at startup to accelerate lighting off the catalytic converter, like blowing on a fire to get it burning, to reduce startup emissions. I don't know if this is specific to manuals or the 3.4 or even 91-93s, but I can't find any information about it in the 1992 factory service manual. If your car has one of these, where does the pump's outlet hose connect where it comes into the engine bay near the AC compressor?
  21. 55trucker
    In the GP it's mounted to the topside of the right rear parcel shelf next to the speaker.
  22. mdpierce8
    Appreciate the response. I’ll see what I can do this weekend.
  23. Schurkey
    My '03 Trailblazer needed the GM/ACDelco "Cold Climate" PS fluid. Whined like a 2-year-old with regular PS fluid. I don't know of any other vehicles that have needed the Cold Climate fluid...but it's available if that's what it takes.
  24. crazyd
    So I know it has been a while, but in case this is still a problem for anyone and for future reference, I found that I have been doing the bleeding procedure incorrectly - and most of the YouTube instructional videos are too. I found the proper procedure in the FSM and I'm posting it here. BLEEDING THE POWER STEERING SYSTEM After replacing the fluid or servicing the power steering hydraulic system, you must bleed air from the system. Air in the system prevents an accurate fluid level reading, causes pump cavitation noise and over time could damage the pump. To bleed the power steering system, proceed as follows: 1. Begin with the engine off, front wheels off the ground. and wheels turned all the way to the left. 2. Add either standard power steering fluid or optional cold climate fluid, to the "FULL COLD" mark on the fluid level indicator. Refer to MAINTENANCE AND LUBRICATION (SECTION OB) for information on power steering fluids. 3. Bleed the system by turning the wheels side to side without hitting the stops. ! Important This may require turning the wheels from side to side several times. Keep the fluid level at the "FULL COLD" mark. Fluid with air in it has a light tan appearance. This air must be eliminated from the fluid before normal steering action can be obtained. Start the engine. With the engine idling, recheck the fluid level. If necessary, add fluid to bring the level to the "FULL COLD" mark. 5. Return the wheels to the center position. Lower front wheels to the ground. Continue running the engine for two or three minutes. 6. Test the vehicle to be sure the steering functions normally and is free from noise. ! Important Inspect for fluid leakage at connection points along the power steering system. 7. Recheck the fluid level as described in Steps 3 and 4 except that the fluid level should now be up to the "FULL HOT" mark after the system has stabilized at its normal operating temperature.
  25. 94 olds vert
    I could be wrong this was a long time ago. In my 1991 Grand prix my keyless entry did not work at all. Figured out the relay was getting power but not doing anything. If I recall it is under the rear package tray? I remember getting in the trunk at one point, but that could have been my convertible. I did also remove my rear interior panels, but can't remember if it was for the keyless entry module. Once you find it, just open it up and look for bad solder joints and touch them up. That's how I fixed mine.
  26. Black92GS
    Is it a coupe? In my Regal, it’s behind the passenger side rear interior panel. I believe all of the 1st gen coupes, save for the convertibles have them in a similar location. It’s roughly behind the red circle.
