Door Handle Problems
Last updated: January 18, 2000
Applies to:
Why it breaks.
The door handle assembly is made of a brittle die-cast aluminum alloy, commonly referred to as "pot metal". It often breaks and causes the door handle to flop around loose. This is because the metal used to cast the door handle itself is too brittle, and over normal use, it will gradually weaken until it snaps.
Buy a new door handle.
Unless you have good welding skills, there is no way to repair the old door handle. The metal is physically broken. The door handle was available with two different types of finish, satin black, and gloss black. Be sure you buy the right kind. A brand new door handle will have a much better movement and feel than a used one from a junkyard, but can cost up to $40 more depending on where you buy it. As of late-1999, the retail price for a door handle is $75.70. Most dealerships will charge about that much, but others may charge more. My local dealer wanted $84 for one! Here are my door handle sources:
Replacement.
Replacing the door handle assembly is very easy. It is replaced from inside the door jamb behind the door handle itself. The door handle assembly is the entire unit, including the exterior pillar trim plate the door handle is mounted in.
  1. Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
  2. Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
  3. Remove one black 14mm nut from the very top of the door handle assembly.
  4. Remove one phillips screw drom the bottom of the door handle assembly.
  5. Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
  6. Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
  7. Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Preventing Door Handle Breakage.
Due to the brittle nature of the material used to make the door handle, the major key to keeping it from breaking is not to be too rough on it. Here are some tips that may really help:
Copyright ©2000 The W-Body Page
